Forums >> General Discussion >> Revit Project Management >> AutoCAD links corrupting Revit file
Fri, Jun 27, 2014 at 11:53:12 AM | AutoCAD links corrupting Revit file
saravernia
My Revit file will crash once in a while and I believe it has to do with a corrupt AutoCAD file.  It seems to work again after I purge, detach xrefs & audit the AutoCAD file but that means that I have to go through this process each time a new consultant drawing is updated.  Thoughts on how to avoid this?
Fri, Jun 27, 2014 at 12:20:03 PM | AutoCAD links corrupting Revit file
You mean linked CAD not xrefs....
If auditing the consultant's file is the problem then it is something in that file.  Have your consultant audit his file before he sends it to you.
Edited on: Fri, Jun 27, 2014 at 12:26:18 PM
Managed links -Autocad paper space
Thu, Mar 8, 2018 at 8:21:28 AM
MANAGE LINKS
Tue, Nov 10, 2009 at 7:41:25 AM
dimension change when importing AutoCad file
Thu, Oct 16, 2014 at 10:59:01 AM
Managing Links
Wed, Jul 28, 2010 at 4:48:23 PM
TAGGING REVIT LINKS
Tue, Oct 20, 2009 at 4:12:14 PM
Page generation time: 5.2501
