Forums >> Revit Building >> Technical Support >> Schedule formats
Fri, Jun 27, 2014 at 11:02:40 AM | Schedule formats
osufuzzy
I am using Revit MEP 2014.
Is there any way to change a mumerical paraameter to text?  I am using electrical parameters, specifically an electrical Wattage parameter.  I can convert it to a numerical value, but I am wanting to add text  ("PER FT")  to the value in the same cell which requires it to be in a text format.
Fri, Jun 27, 2014 at 12:03:32 PM | Schedule formats
Sorry - there are no real text functions in Revit but you can have units.
Wed, Jul 2, 2014 at 9:45:24 AM | Schedule formats
osufuzzy
That is what I was afraid of.  Units will not do what the engineer wants either.  Thanks!
Wed, Jul 2, 2014 at 9:56:42 AM | Schedule formats
Why not just add a seperate text column that has the "per foot" and format the cells so that it looks like one cell.
Thu, Jul 3, 2014 at 3:28:35 PM | Schedule formats
osufuzzy
Using the Revit Schedules, you can either have lines dividing your cells or no lines at all.  There isn't an option to remove a line between cells.
Thu, Jul 3, 2014 at 3:56:31 PM | Schedule formats
Not true... here is a schedule with both sides of the door height column removed.
Thu, Jul 3, 2014 at 4:11:38 PM | Schedule formats
osufuzzy
This is as close as I could get.  Re: attached
Thu, Jul 3, 2014 at 4:26:31 PM | Schedule formats
osufuzzy
I have looked for that before,  now I see it for the headers, but it doesn't want to give me the option for the body.  In the attached image I have tried selecting both the two cells and the entire columns and both ways, the borders options are not available.
Mon, Jul 7, 2014 at 8:27:41 AM | Schedule formats
Click on the schedule column A-B-C.... Then pick the borders tab.
Wed, Jul 16, 2014 at 11:30:26 AM | Schedule formats
osufuzzy
Got busy and took me a while to get back to this.
Thanks, I can get it to work now.  Sometimes you just have to hit me over the head with the letters...  I kept highlighting everything below the letters and could not get it to work for me.  Now I see.
Have a good one.
How to print different sheet formats in PDF?
Mon, Jun 5, 2023 at 2:07:16 PM
Index or Schedule Linked Files
Tue, Oct 22, 2013 at 9:16:38 AM
Filter Overrides
Thu, Sep 27, 2012 at 4:20:34 AM
STL or VRML formats
Tue, Apr 25, 2006 at 5:31:56 PM
New text formats
Wed, May 25, 2005 at 2:31:44 AM
Page generation time: 0.7480
