19 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> Print at Scale via Jpeg
28 Posts No Rating |
Hello
Instead of making several A3 PDF prints of a set of sheets I prefere making an Image export of several Sheets and combine them later into an A3 booklet via Acrobat. For me this worked faster than combining A3 PDF pages together in an booklet.
But I discovered now (revit 2014) that printing scale is not correct in revit. My preferences were printing (exporting image..) at an 100% scale and a dpi setting of 300. The results are A3 images with a measure of ca 700x500mm when I import them in Acrobat. Anyone a clou how to get exact measured drawings when exporting tot Jpeg images ?
Of course I know the method of printing the sheets via PDF creator or comparable but that is a difficult and slow method compared to making Jpeg images..
Best regards
Henk
I can't answer on how to do what you want but printing jpg images has to be much slower then pdf's. We use cute and print one combined pdf - all sheets. No combining necessary.
But anyway when priinting or exporting to Jpeg at 100% scale it's not right that drawings are two times larger at once..
HOW DO I PRINT MY JPEG IMAGE? |
Mon, Jun 4, 2012 at 7:09:49 AM
Print!!!!!! |
Fri, Jul 18, 2008 at 1:59:06 PM
RA2008: Scale Watermark |
Tue, Apr 29, 2008 at 10:18:19 AM
Print views to scale on a sheet without a titleblock |
Thu, Nov 12, 2009 at 7:02:51 AM
Fix scale in jpeg map |
Fri, Jun 16, 2006 at 11:43:55 AM
