Forums >> Revit Building >> Tips & Tricks >> Can I change the 'ctrl + Tab' shortcut to switch between windows to a (2) digit?
Thu, Jun 26, 2014 at 2:25:05 PM | Can I change the 'ctrl + Tab' shortcut to switch between windows to a (2) digit?
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Hello there,
I recently made the switch to purchase a usb separate numpad and changed all my shortcuts to (2) digit shortcuts...it's awesome!  I know nerd right?
Anyways, I wish there was a way to add a shortcut to 'ctrl + tab' or someway to alternate between windows.  Is there a way to do this?  I couldn't find it in the Keyboard Shortcuts window dialog?  If there's another way you recommend I'm all ears!  I do have a Tab on my Numpad and an Esc.  But no CTRL Sad
While I'm at it, is there a way to close just the window?  I couldn't find that in the keyboard shortcuts either, other than closing the entire project of windows.
Thanks,
Lorne
PS - I'm happy to share my keyboard shortcuts with whomever wants them!  Got an excel keyboard shortcut cheat sheet as well on bottom of my monitor.
Denver, CO
Revit Architecture
Thu, Jun 26, 2014 at 2:37:34 PM | Can I change the 'ctrl + Tab' shortcut to switch between windows to a (2) digit?
I like to rip off the view tab from the ribbon and drop it in the lower corner of my screen so I can easily jump between windows.
Thu, Jun 26, 2014 at 2:51:35 PM | Can I change the 'ctrl + Tab' shortcut to switch between windows to a (2) digit?
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Thanks WWHub,
So you're basically saying there is no way to add these shortcuts to 2 digit shortcuts?  I wanted to make switch windows '++'!  It'd be so convenient Smile
Denver, CO
Revit Architecture
View Previous
Fri, Nov 13, 2009 at 12:21:46 PM
window opening doesn't show in floor plan view
Mon, Oct 3, 2005 at 7:59:15 PM
I can't assign a switch ID to a switch
Wed, Dec 9, 2020 at 5:42:46 PM
'Out of Memory' pop up
Tue, Sep 6, 2005 at 3:16:07 PM
Keyboard Shortcuts Won't Open/Show
Tue, Feb 26, 2013 at 11:09:04 AM
Page generation time: 2.2967
