Forums >> Community >> The Studio >> Craftsman Column Problems
Wed, Jun 25, 2014 at 12:58:05 PM | Craftsman Column Problems
heintz89
Hi there. I am a little knew to Revit. I am having trouble with the Craftman Columns in the Library. I have tried multiple different ones. I have been looking at the created columns with the base with the column on top. I can easily shift the height of the caps and base but none of them will alow me to adjust the actual column placement. In other words, when I go to change the cap height of shift the base height, there are gaps between the base and the column and/or the cap and the column. Does anyone know how I can change this or have a column that I would be able to change this in?I attached the different files I have tried to use. They are all pretty similar.
Thanks.
Wed, Jun 25, 2014 at 2:08:11 PM | Craftsman Column Problems
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You need to align and lock the base that is not moving with the base that is moving up.  This one should work now.
Wed, Jun 25, 2014 at 2:16:06 PM | Craftsman Column Problems
heintz89
Thank you. That fixed the column from seperating from the base. However, now the height can't be adjusted though
TAPERED CRAFTSMAN STYLE COLUMN
Sat, Jul 1, 2006 at 10:25:55 AM
Trim on slanted column
Mon, Sep 8, 2008 at 1:20:01 PM
Model Line constraints in family editor
Mon, Aug 15, 2011 at 11:46:25 AM
PROBLEMS EXPORTING GRAPHIC COLUMN SCHEDULE TO AUTOCAD
Thu, Jan 27, 2011 at 12:23:31 PM
DISPLAY COLUMN LABELS
Wed, Sep 8, 2010 at 3:53:41 AM
Page generation time: 0.2115
