13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> Schedule column width: Sheet vs. edit view
19 Posts No Rating |
Running Revit 15. Skipped 14, so don't know if this is a 14 or 15 issue.
It used to be that the width of the schedule's columns on the sheet was independent of their width in the edit view. Now I find that making them wide in the edit view also makes them wide in the sheet view. Wouldn't be a problem, except that trying to edit much text when they are narrow is a real pain in the rear.
I haven't seen any other posts on this. Anyone else? Solutions?
14 has this as well and maybe even 13. It will cause us all problems unless you use a working schedule to edit data and resize your columns as required to do that.
Locking column width and row height for schedules |
Fri, Feb 17, 2017 at 9:41:08 AM
12
Word wrap in schedules? |
Wed, Jun 23, 2010 at 10:26:40 AM
Text Wrapping in Door Schedule (in modify page, not when placed on sheet) |
Tue, Jan 17, 2012 at 9:48:23 AM
View List and Sheet Index |
Wed, Nov 24, 2004 at 6:58:59 PM
can you get tonnage or weight from the schedules command? |
Fri, Feb 19, 2010 at 3:14:16 AM
