Forums >> Revit Building >> Technical Support >> Dividing a line
Wed, Mar 1, 2006 at 9:55:23 PM | Dividing a line
cadjockey
Hi All, I'm tied. The function is probably there. I just can't see it. How do I divide a line into equal segments. Live the DIVIDE command in Autocad? Thanks. cadjockey
Wed, Mar 1, 2006 at 10:03:05 PM | RE: Dividing a line
eldados
eldados Avatar
4.5 Stars: 8 Votes
IT'S A PAIN IN THE b$#%. YOU WILL NEED TO SPLIT THE LINE, DIMENSION TO THE END POINTS OF EACH SEGMENT, AND CLICK THE EQ BUTTON...
Integrator
KarelCAD
Wed, Mar 1, 2006 at 10:22:14 PM | RE: Dividing a line
cadjockey
NO WAY! You can't be serious? cadjockey
Wed, Mar 1, 2006 at 10:59:42 PM | RE: Dividing a line
eldados
eldados Avatar
4.5 Stars: 8 Votes
yeah mate, revit still needs to pick it's act when it comes to drafting tools... Sad
Integrator
KarelCAD
Tue, Sep 4, 2007 at 9:06:00 PM | Dividing a line
Oak3s
Incase someone stumbles across this as i did use the array command.
Example:
if you have a horizontal line you want divided into 6 segments i would draw a vertical line at the left end point of the horizontal line.
select the vertical line and hit the array button.
in the array command make sure you are doing a linear array for this example.
change the "Number:" to however many segments you want + 1.
change the "Move To:" to "Last".
then pick the start point (the intersection of the two lines).
then pick the end point (the opposite end of your horizontal line).
there it is. this thread was back in May of 2006 so the version then might not have done this. in 2008 it works. i hope this helps.
dividing project and linking files : structure, interior/envelope walls
Wed, Apr 6, 2005 at 6:22:48 PM
Line weights for hatch?
Mon, Mar 23, 2009 at 2:24:48 AM
No dividing lines on sections ?
Sat, Mar 14, 2009 at 2:39:37 PM
Dividing a 2d line
Thu, May 26, 2005 at 11:00:52 AM
Help dividing surface of imported .sat file to create curtain system
Sat, Nov 13, 2010 at 12:44:51 PM
Page generation time: 0.7005
