Forums >> General Discussion >> Revit Project Management >> One family parameter has formula one has none
Wed, Jun 25, 2014 at 10:26:07 AM | One family parameter has formula one has none
TimothyLiv
Can I have a formula driven value in one family's parameter and then swap that family to another similar family with the same parameter but without the restrictions from the formula? Basically, I would like to pre-calculate intervals based on height but then have the freedom to swap families at the project level and the pre-calculated values would pass to the new family as values and not formula. Kinda like, Paste Special -> Values... Thank you, Timothy Livingston
Wed, Jun 25, 2014 at 10:29:04 AM | One family parameter has formula one has none
For questions like this....gee - why don't you try it?  Seems like it would teach you better and is so easy to do.
Wed, Jun 25, 2014 at 11:09:40 AM | One family parameter has formula one has none
TimothyLiv
And for answers like this....Sad
I have tried it thanks.
When I try to swap the formula driven family parameter, with the un-driven family parameter, the undriven values keep reverting back to the values in the family editor.
Always a pleasure reading your knee-jerk posts WW.
Thanks,
Timothy Livingston
Wed, Jun 25, 2014 at 11:21:14 AM | One family parameter has formula one has none
I think my suggestion was pretty good.  You answered it for all of us - thank you.
See how easy that was?
Wed, Jun 25, 2014 at 11:26:04 AM | One family parameter has formula one has none
TimothyLiv
If you don't have an answer or suggestion, don't reply.
Thanks,
Timothy Livingston
Wed, Jun 25, 2014 at 11:36:57 AM | One family parameter has formula one has none
TimothyLiv
Thanks,
Timothy Livingston
Wed, Jun 25, 2014 at 11:46:03 AM | One family parameter has formula one has none
You really can't offend me because I just don't care what you think.  I don't have time to deal with people that want others to do their work.  There is a word for that but I didn't use it.  I admire users that try an idea and come with a good question when they are stumped.  People that do that are creative and responsible.   You didn't do that.
If you had truely tried the process ahead of time then your follow up should have been your original question.  But I doubt that you had.
Wed, Jun 25, 2014 at 1:05:54 PM | One family parameter has formula one has none
TimothyLiv
Of course I have tried it!!
I have only use this forum in emergencies, knowing I would get some effed up response from WW.
My question is looking for tips or known limitations, best proactices, etc.
Should I be using a reporting parameter? Use a type family approach?
Things that could lead me in the right direction. Can you please stop responding to my posts all together?
I would like to hear what OTHER people say.
Referencing a Shared Parameter in a Family parameter formula.
Thu, Jan 29, 2015 at 1:26:24 PM
formula using <Family type> parameter
Mon, Nov 1, 2010 at 10:01:58 AM
<Family Type> parameter can't be controlled by formula. What else can we do? [ 1 2 ]
Tue, Aug 27, 2013 at 3:53:53 AM
29
Parameter Formula
Fri, Mar 5, 2010 at 12:09:09 PM
Parameter names with dashes - problem with formula
Tue, Aug 31, 2010 at 10:28:39 AM
Page generation time: 1.4401
