Forums >> Revit Building >> Technical Support >> Stair railing issue
Wed, Jun 25, 2014 at 7:57:35 AM | Stair railing issue
jmqrsq
5 Stars: 3 Votes
can anyone tell me how to fix this? The balusters do not stop at the stringer slop the whole length of the rail. Only part of it. I have tried everything I know of to fix it with zero luck. Thanks.
Wed, Jun 25, 2014 at 8:10:24 AM | Stair railing issue
I see a vertical line in that stringer.  Are these two seperate stairs?  Why?  That could be your problem.
...now I see more vertical lines.... maybe not seperate stairs but a railing sketch that doesn't stay over the host?
Really hard to say without actually examining the model.
BTW - do you really want wall brackets on the center guard handrail?  I don't think so.
Edited on: Wed, Jun 25, 2014 at 8:23:27 AM
Wed, Jun 25, 2014 at 9:12:28 AM | Stair railing issue
jmqrsq
5 Stars: 3 Votes
Those vertical lines are a product of the vid card. Here is another view of it closer. Those are remnants of the balusters going through the stringer.
I am attaching a portion of the file for you to look at. I do have seperate piences of railing I am using along the back wall in order to achieve a more accurate depiction of what will be constructed. I just can't figure out why it will not host those to the stringer. Funny thing is if you look at the bottom part of that run the bottoms of the ballusters do not line up with the bottom rail. They are gradually dropping at a rate slower than the slope of the stair.
Wed, Jun 25, 2014 at 9:20:21 AM | Stair railing issue
Look again at your balluster setup.  You obviously have at least two ballusters in the list because one does not extend to the stringer.  If you have multuples, perhaps some are not set to host.
Wed, Jun 25, 2014 at 10:37:55 AM | Stair railing issue
jmqrsq
5 Stars: 3 Votes
Correct. I do have two balusters. One needs to span the bottom rail to the top rail. The other should be going from the stringer to the top rail as supports. Ultimately I want the support ballusters to be 2 feet apart with the intermediates filling in at 6" increments. But thats a different issue I am working on.
In this case it is working everywhere except that oddball run....
Wed, Jun 25, 2014 at 10:52:03 AM | Stair railing issue
Do you have all updates installed.  Don't just respond with yes, post what Revit and what updates shown in the about under the ? dropdown. < We have seen many posters that don't know how to check their updates and they think they are up to date.   If that isn't the issue then I'm out of advice.
Wed, Jun 25, 2014 at 11:21:35 AM | Stair railing issue
jmqrsq
5 Stars: 3 Votes
Yep. All up to date.
Not sure what the deal is. Maybe I will delete that portion and re sketch it....
Wed, Jun 25, 2014 at 11:34:08 AM | Stair railing issue
2015 railings don't seem to recognize their host when drawn over stringers.  I don't remember this being an issue before.  Try refining your railing with different offsets from the railing sketch line so that the sketch stays on the stairs and not the stringer.
Curved stair and railing issue
Tue, Oct 4, 2016 at 1:32:22 PM
Add railing to existing stair
Tue, Oct 29, 2013 at 7:49:39 PM
stair railing transition at landing issue (2015)
Wed, Sep 16, 2015 at 9:29:50 AM
Railing at stair bottom!
Thu, Feb 28, 2008 at 10:57:33 AM
Railing wont host to stair created in design option
Mon, Oct 24, 2011 at 3:54:39 PM
Page generation time: 2.4804
