26 Users Online (24 Members):
Forums >> Community >> Newbies >> Shape Editing Tab for "Foundation Slabs"
8 Posts No Rating |
Can you place points to modify sub elements at a "foundation" slab. The Shape Editing tool dose not come up when I highlight the foundation slab. I know you can do it at "floor" slabs.
You mean a structural floor? Yes you can, i still get all the options. You'll need to tell us more about what your doing, what version of Revit, do you have all the updates installed?
8 Posts No Rating |
Not a structural floor, a "Foundation Slab" found in the foundations Tab. I am using R13
A foundation slab is just a slab, all you can do is add a slope arrow. I personally would use a structural floor over a slab unless you need if for some sort of scheduling reason.
8 Posts No Rating |
That’s what I thought. I wonder why Revit is set up like this. If any slab needs to nave sub points it’s a foundation slab. An example would be a slab on grade sloping to multiple floor drains.
This may really be a terminology problem. We don't consider slabs on grade to be foundation slabs. They are just another floor. Actually, I don't know of anyone here referring to foundation slabs. We have matt foundations for large areas that may have multiple elements loading them. If structural items "sit" on a SOG, then we might have reiforced areas for that or thickened slab areas but we still consider this to be a floor and model accordingly.
Walls cutting slabs |
Fri, Jan 23, 2009 at 1:57:20 PM
Create a "Foundation Wall system family?" |
Tue, Aug 3, 2010 at 9:50:54 PM
Basement Wall Function: "Foundation" or "Exterior"? |
Fri, Mar 26, 2010 at 12:27:21 PM
No "ROOMS" tab |
Tue, Jan 13, 2009 at 4:19:33 PM
Shape editing in Revit 2010 |
Mon, Apr 5, 2010 at 5:28:49 PM
