Forums >> Revit Building >> Technical Support >> Site Problem
Wed, Mar 1, 2006 at 6:31:30 PM | Site Problem
COLLEDGE
Have used the link file method to position 9 units on a sloping site with considerable fall. Require the correct method to create sloping driveways & level building areas. I can split the surface & apply new levels but how do I grade the untouched surface exactly back into the adjusted surface. Do you have to record every elevation point alteration on the modified driveway portion & then apply these values to the bordering portions. There must be a better method ! Rgds Steve
Wed, Mar 1, 2006 at 9:47:10 PM | RE: Site Problem
eldados
eldados Avatar
4.5 Stars: 8 Votes
sad to say that Revit site tools are way off being usable when it comes to roads, curbs etc. have a look at the tutorial I wrote, complex slabs and paths...
Integrator
KarelCAD
Thu, Mar 2, 2006 at 3:56:11 AM | RE: Site Problem
Steve1959
Thank you once again. I was afraid you would say that. Will look at the tutorial and battle through. Sounds like the new release wont help either! Pity they wont add the stuff we do need instead of stuff most of us cant even spell! Regards Steve Ballina NSW (Nearly as much Sun)
Thu, Mar 2, 2006 at 6:05:07 PM | RE: Site Problem
eldados
eldados Avatar
4.5 Stars: 8 Votes
I agree. though the developers are working hard on 9 and 10 we are still missing so many things we asked for... that's why I'm waiting for 12 Smile
Integrator
KarelCAD
Problem with Reigion Hatching on Site Plan [ 1 2 ]
Tue, Feb 25, 2014 at 4:19:15 PM
26
Linking the same revit model into a site with different RL's
Wed, Sep 12, 2007 at 9:14:42 PM
invisible road carparks and landscape on site plan
Fri, Aug 28, 2009 at 6:44:33 AM
Problem with Site Pads
Thu, Oct 13, 2011 at 4:02:37 AM
How to cut the building and not the site?
Thu, Apr 28, 2011 at 5:45:35 PM
Page generation time: 2.8792
