Forums >> Revit Building >> Technical Support >> Render in cloud / sun settings
Sun, Jun 22, 2014 at 1:10:32 PM | Render in cloud / sun settings
Valentinho
Hello,
So, when you render in cloud the sun settings will be automatically delivered in your render. However, it seems that even though I turn my model in the right position to avoid too much shadow that the sun turns with it. How can I have any influence on where the shadows will fall?
Tue, Jul 22, 2014 at 4:42:45 PM | Render in cloud / sun settings
grid
What do you mean by 'rotate your model'? Are you rotating the geometry or changing the sun settings? Use the Sun Settings options by clicking on the sun at the bottom of the screen. Set it to 'Still' and adjust it to the desired position. The cloud render should match the shadows in your model.
Palm Springs Architect using Revit LT!
Cloud render quality
Fri, Apr 5, 2013 at 3:50:00 PM
Rendering in cloud
Fri, Jan 6, 2017 at 7:34:57 PM
Render exterior view with artificial lights - how to make interior glow?
Sun, Mar 11, 2012 at 12:45:28 PM
Render in Cloud Problem
Fri, May 24, 2013 at 8:19:23 AM
View template - different sun settings
Wed, Nov 28, 2012 at 9:04:16 AM
Page generation time: 0.9714
