Forums >> Revit Building >> Technical Support >> Labeling/Schedule Piping per Room Location
Fri, Jun 20, 2014 at 3:57:54 PM | Labeling/Schedule Piping per Room Location
AStelzer
I am working on a water plant project and it has come time to start teching out our sheets. This is our first revit project. I am trying to label pipe, pipe fittings and pipe accessories. I created schedules however these schedules include the whole project and I am looking for schedules per room. I tried creating a room schedule with an embedded pipe schedul, but the only pipe fields are pipe fittings and pipe accessories.. Can someone give me direction on the best way to label pipes per room in Revit 2015?? Thanks
Mon, Jun 23, 2014 at 6:54:45 AM | Labeling/Schedule Piping per Room Location
Although I don't do MEP, I can say that I doubt that you can do this.  Elements that typically span multiple areas like walls, floors and roofs do not associate with any areas and I would assume it is the same with pipes.
Embedded window schedule in Room schedule
Thu, Nov 19, 2015 at 1:03:49 AM
Find a specific room in the room schedule
Thu, Jul 4, 2019 at 2:08:03 AM
automating door schedule ( From room # To Room #)
Thu, Jun 20, 2019 at 2:14:07 PM
Room finish Schedule showing Deleted Rooms
Wed, Aug 26, 2009 at 3:56:37 PM
Room names Not showing in Schedule [ 1 2 ]
Tue, Jul 24, 2012 at 7:05:38 AM
20
Page generation time: 0.3726
