Forums >> Revit Systems >> Technical Support >> Nested family plumbing fixture schedule
Thu, Jun 19, 2014 at 10:10:28 AM | Nested family plumbing fixture schedule - 2014 Revit MEP
blucivic1
I've created a few nested fixtures and I am having trouble with scheduling a single family with different parameters. The best our BIM team could come up with was creating a dummy schedule. I've attached the file that I'm working with. I basically tried to follow the advice this thread, but I seem to bot be doing something right:
http://forums.augi.com/showthread.php?123213-Fixture-Schedule-With-nested-Families-shows-all-or-nothing
Edited on: Thu, Jun 19, 2014 at 3:10:19 PM
Thu, Jun 19, 2014 at 10:17:48 AM | Nested family plumbing fixture schedule
In order to schedule nested families, the nested family HAS TO BE SET TO SHARED.
Thu, Jun 19, 2014 at 10:32:55 AM | Nested family plumbing fixture schedule
blucivic1
Already did that. Not sure if you understand hat I'm asking. Hopefully the pic helps
Thu, Jun 19, 2014 at 10:46:02 AM | Nested family plumbing fixture schedule
Sorry but your last post does not explain your question.
Your question was: "I am having trouble with scheduling a single family with different parameters."
   ... Simply explain that.
Thu, Jun 19, 2014 at 12:51:04 PM | Nested family plumbing fixture schedule
blucivic1
hopefully my last post cleared up some confusion. every time I change a family type, it changes for all of that fixture type. the individual parts are Type and the combined family is Instance. if i change everything to Instance, nothing shows up on the schedule.
Edited on: Thu, Jun 19, 2014 at 2:08:10 PM
Thu, Jun 19, 2014 at 1:16:24 PM | Nested family plumbing fixture schedule
I highly recommend that you download the families guide from autodesk as it explains this process.  Here is a clip of the appendix and the associated chapter that tells you how to do this.
Fri, Jul 11, 2014 at 12:08:03 PM | Nested family plumbing fixture schedule
gatoviejo
Questions.
You can calculate the diameter of pipe for sanitary system as it takes revit in a system of cold water?
Please help
Plumbing Fixtuer Tags
Wed, Feb 4, 2015 at 1:41:00 PM
create a plumbing fixture count schedule
Tue, Apr 10, 2018 at 1:08:32 AM
Plumbing Fixture Schedule
Thu, Jan 30, 2014 at 10:36:00 AM
Light fixture not appearing in fixture schedule
Thu, May 7, 2015 at 7:26:00 AM
"Schedule Level" Parameter in Plumbing Fixture Family
Thu, Jul 3, 2014 at 2:32:51 PM
Page generation time: 0.7874
