Forums >> Revit Building >> Technical Support >> CREATING A TOPO FROM A CIVIL CAD FILE
Tue, Jun 17, 2014 at 7:50:33 AM | CREATING A TOPO FROM A CIVIL CAD FILE
Wader
I'm having this continual problem of not being able to select an imported civil DWG file in order to create a topo surface.
I link the civil DWG file into my revit model but when I try to select the dwg in order to create a topo surface its greyed out
and cannot actually be selected.  This have been an issue for quite some time but it has worked properly in the past.
Any idea as to why I can't pick the linked file?
thanks for any insight.
Wader
Tue, Jun 17, 2014 at 8:02:01 AM | CREATING A TOPO FROM A CIVIL CAD FILE
Thread Post Kudo! #2
Contrary to normal Revit processes, this is one place that you MUST import and not link.
Import into your working site view only and pick that to create your topography.
Once the topography is created, you should discard the import and use the linked file for other data that can be updated.
Correction.... The import MUST be for all views so that it is a 3D import so DON'T check the "This view only" box.
Edited on: Tue, Jun 17, 2014 at 8:12:47 AM
Thu, Jun 19, 2014 at 6:51:20 AM | CREATING A TOPO FROM A CIVIL CAD FILE
Wader
WWHub:
I've tried it both linked and unlinked and the same issue exists.........I can't select the dwg to make the topo??
Wader
Thu, Jun 19, 2014 at 7:16:19 AM | CREATING A TOPO FROM A CIVIL CAD FILE
First - WHAT REVIT?  WHAT UPDATES?
This is a user error but it is hard for us to diagnose.  You say you can't select it at all.  Tell us your process and show us your screen image.
Sun, Nov 9, 2014 at 4:36:02 PM |
heberaye
Quoting WWHub from 2014-06-17 08:02:01
Edited on: Tue, Jun 17, 2014 at 8:12:47 AM"
I Had the same issue with Revit 2014 but the suggestion above worked for me. The essential thing is importing to all views as per WWHub's instruction above.
Fri, Sep 29, 2017 at 3:22:33 PM | CREATING A TOPO FROM A CIVIL CAD FILE
elbundo
In 90% of these issues it has to do with the process when the file was either linked or imported. The following below is a process I have found to work every time. Before I do that list one process you should do or have done: open the dwg file and make sure the contours are actually 3D objects on the correct elevation plane. And there other is to record the layer names for the major and minor contours. I have had several instances where contours were are several different layer names. OK, here is the workflow:
Working in the Revit file
1 Find out what you expect the finish floor elevation value will be. Open an elevation view> set a new level at the distance SeaLevel would be below your finish floor level - name that new level view Sea Level; make it your current view
2 At the Insert tab select Link or Import, make sure "Current view only" is UNCHECKED - this is critical and one of the 90% problems
3 Import units: Auto-Detect, Positioning: Auto - Center to Center, select the Open
4 Now make your Site plan view current
5 Set the Orientation at the Properties Palette to True North
6 Rotate the DWG file to align with your projects Project North
Manage tab> Project Location panel>Coordinates>Acquire or Publish (select the one that meets your needs - in this instance Acquire is the one I use most ofter - I get the advantage to the Survey Point from the civils work
8 Select the dwg and at the Properties Palette you will see the site position is set to (Other section) Not Shared - select that button
9 At the Choose site>Record curent position...>select the Change button
10 At the Location Weather and Site dialogue box select the Duplicate button and provide a name for the location - select all OK buttons
11 At the Manage tab>Maanage Links>CAD Formats tab>select the name you used and at the bottom left select Save Positions
This will record the coordinates back to the civil / survey file. Now your are set to create a topo. And more important you have created a site plan that can show you True North and Project North - how cool is that?
Now you can go to the Massing & Site tab to create your Revit topgraphic model. Again, you need to know the layers the contours are on. If you still cannot make a topo from the dwg file then the contours may be flat with an elevation value of 0. The option then is to use the dwg as a template tand use the Place Point tool to create the topo map. If you are going to do any grading make sure the new topo Phasing is set to Existing. And I would give it a name like (e) topo - I used lower case for eixisting conditions like this.
Hope this helps,
matching contour lines from civil CAD when creating Topography (2019)
Fri, Dec 4, 2020 at 2:09:46 PM
2021 proper/typical method to insert civil CAD to generate revit topo then place
Thu, Jun 10, 2021 at 10:36:47 AM
Linking a civil 3D CAD file to Revit Architecture 2012
Thu, Jan 12, 2012 at 6:48:02 PM
Topo import from CAD to Revit - Scale is off - Revit 2014
Sat, Feb 28, 2015 at 11:34:03 PM
topo contours are offsetting in z direction
Fri, Mar 27, 2015 at 5:42:45 PM
Page generation time: 3.5388
