Forums >> Revit Building >> Technical Support >> Parametric Wall with random void pattern
Mon, Jun 16, 2014 at 3:31:31 PM | Parametric Wall with random void pattern
auP81390
I am going back through some of my old studio projects from school and I ran into one with a major modeling issue. The point of the project was to analyze an object with thermal, aero or hydro dynamic properties and to determine how to use it in building construction to eliminate the need for mechanical systems. My object was a golf ball, I was wondering if there was a way to create either a random and/or repeating surface dimpling pattern with variable depths and sizes. I guess it does not need to be a wall object but would need to be an adaptive component. The construction of the wall would be concrete with the dimpling pattern applied, It would be nice to have the option to change the dimpling pattern in order to test the aerodynamic properties of each. I did this previously in autocad using extrusions and cutting voids out of it. This is long and tedious. Any input would be appreciated.
pattern issue-void cutting through wall and sweeps
Fri, Sep 23, 2011 at 2:24:08 PM
Random LVT floor pattern
Wed, Sep 8, 2021 at 12:26:39 PM
Random stone walls
Thu, Jun 26, 2008 at 5:04:39 PM
Parametric Void within a Solid
Fri, Aug 27, 2010 at 11:29:58 AM
Surface pattern move/align/adjust problems [ 1 2 ]
Thu, Sep 17, 2020 at 10:29:33 AM
19
Page generation time: 5.7845
