10 Users Online (8 Members):
Forums >> Revit Structure >> Technical Support >> Material Creation
0 Posts No Rating |
Wow, did Autodesk intend to make materials a wholly frustrating experience?
I am a brand new Revit baby obviously overstepping my bounds. I felt pretty clever working out the topography editor in a few minutes. Then I created a building pad as a base for some fencing (because the fences dont follow the topo profile). So far so good...
Im trying to create a reasonable-looking riding ring with a woodchip surface. So I selected the building pad and created a duplicate pad to work my magic on. Opened the structure editor, flipped through a few materials and decided to make my own. I duplicated my grass material (which i created earlier by duplicating the earth material) and selected loose gravel as an image and used the corresponding bump map. Tinted it to orange and hit "OK". Pretty good for a novice right?
Apparently I have much to learn, Revit decided it liked my chips so much that it updated my grass and earth materials to match (which updated my topo)....... After fussing about a little and repeating the problem a few times I figured I would try to set the building pad to copper. Which worked fine, copper building pad and grassy topo.
I guess duplicated materials are linked in some way? Or should I just resign myself to shades of grey? Does anyone else find material editing vexing?
I've done a little searching on the topic and yes I have the building pad selected (created a duplicate pad for editing).
Thanks for the help!
You don't say what Revit!
Revit 2013, 2014 and 2015 have assets as well as materials. That is where your problem lies. This may help you:
http://www.cadalyst.com/cad/revit/understanding-autodesk-revit-materials-17422
0 Posts No Rating |
Excellent! Thanks for the link.
Revit 2014 BTW.
Still seems ridiculously complicated. But Im not a 3D modeller....
Material Creation |
Sun, Apr 26, 2009 at 12:08:51 PM
Revit 2013 Material Creation |
Fri, Mar 15, 2013 at 3:35:40 PM
Creation of a new Material Surface Pattern |
Wed, Sep 21, 2011 at 6:43:53 PM
Assigning a material to an extrusion - Family creation |
Sun, Feb 28, 2010 at 2:08:39 AM
mass, edge creation r2011 |
Fri, Oct 29, 2010 at 6:37:04 PM
