Forums >> Community >> Newbies >> How do I change the view line on the Elevation?
Fri, Jun 13, 2014 at 6:10:13 PM | How do I change the view line on the Elevation?
BlueFairy
There is a line showing the plane where the view starts associated with the exterior elevation tag. That line is in front of a partition wall that blocks to view of the building elevation. When I try to move it, it does not move. It moves only side to side. How do I move that view line to be on the other side of the partition wall so I can see the building elevation?
Sat, Jun 14, 2014 at 9:43:45 AM | How do I change the view line on the Elevation?
mansell5
3.5 Stars: 4 Votes
in your plan view, click on the elevation tag pointer of the elevation in question.
that opens the elevation dialogue box.
scroll down to extents .
look for far clipping. click the box next to it and another box opens up on screen with 3 options.
select clip with line, then click ok to close box,  this will show the elevation depth on floor plan (dashed rectangle with 2 blue drag
triangles for you to adjust depth of your elevation view.)
cheers
locking detail line to ceiling for elevation view.
Fri, Jan 23, 2009 at 4:00:42 PM
elevation tag line weight
Wed, Dec 17, 2008 at 1:55:39 PM
Hiding View Name in Elevation View Tags
Fri, Jan 21, 2011 at 6:47:39 PM
Elevation Line Extensions
Mon, Apr 30, 2012 at 8:08:08 AM
Trouble is Site in Elevation
Wed, Apr 25, 2007 at 5:50:59 PM
Page generation time: 1.4597
