Forums >> Revit Structure >> Technical Support >> Beam Annotation: Beam Elevations and Parentheses
Fri, Jun 13, 2014 at 9:11:43 AM | Beam Annotation: Beam Elevations and Parentheses
abusementpark
Hello,
Everytime I use the Beam Annotations command to show beam sizes and beam elevation, the beam elevation comes in without parentheses for the prefix and suffix, and I have to manually change it.  Is there a way to set it up such that my beam elevations will automatically have the parentheses when I use the Beam Annotations command?
I'm using Revit Structure 2014.
Thanks!
Fri, Jun 13, 2014 at 3:15:10 PM | Beam Annotation: Beam Elevations and Parentheses
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Are you placing a 'structural framing tag' ? If so I don't see a supplied tag that puts in the 'elevation' with or without brackets so I made one and attached it with an image file showing what it does.
Mon, Jun 16, 2014 at 8:29:22 AM | Beam Annotation: Beam Elevations and Parentheses
abusementpark
dgcad,
How did you make that?
I have attached the exact format I am looking for.
Steel Beam to Beam Connection
Fri, Jun 18, 2010 at 1:54:36 PM
Beam & Beam systems
Tue, Oct 21, 2008 at 4:36:54 PM
Trusses as beam systems
Tue, Dec 22, 2009 at 10:50:48 AM
beam finishes
Wed, Sep 19, 2012 at 3:11:30 PM
Sloped Beam Systems Q's
Mon, Nov 14, 2016 at 11:48:46 AM
Page generation time: 0.4008
