Forums >> Revit Building >> Technical Support >> Line Thru Section Tag Head
Fri, Jun 13, 2014 at 8:20:26 AM | Line Thru Section Tag Head
ml22
Anyone had this problem?  The line of the section tag runs through the tag head.  Image attached.
Thanks,
M
Fri, Jun 13, 2014 at 9:09:58 AM | Line Thru Section Tag Head
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Is this an OOTB section head or did you create it?
Fri, Jun 13, 2014 at 10:37:16 AM | Line Thru Section Tag Head
ml22
OOTB, I believe.  The person that created our master drawing template is long gone.  If it is not the OOTB original, how can I replace it?
Fri, Jun 13, 2014 at 11:30:22 AM | Line Thru Section Tag Head
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Click on the section and edit the type and see if you can change the head to something else. Let me know the results.
Fri, Jun 13, 2014 at 12:10:13 PM | Line Thru Section Tag Head
ml22
Found the problem.  Some knucklehead added a line to Section Head - Filled.rfa
All is fine now.
Thanks for the lead.
Section Tag Head/ Line issues
Thu, Apr 20, 2017 at 4:05:07 PM
Gap between section head and tail and middle line
Mon, Aug 20, 2012 at 8:13:56 AM
Section Head
Tue, Jun 18, 2013 at 11:22:52 AM
section head problem?
Fri, Feb 17, 2012 at 1:58:32 PM
Section Tag Head Size
Thu, Feb 28, 2008 at 10:51:57 AM
Page generation time: 6.4178
