Forums >> Community >> Newbies >> Parametric metal panel help
Thu, Jun 12, 2014 at 11:52:44 AM | Parametric metal panel help
blawlz
Hi All,
Im fairly new to creating revit families. I have a building that has pre fab metal panel cladding all around the building.
Ive created and attatched the family, its simple for now, just steel structure holding a profile made to look like steel decking, hosted on a wall.
I had to create the profile for the metal panel in a side elevation, and i cant figure out how to lock it to reference plans to adjust the width (front elevation or plan). How would i do this?
As well, im looking to have it so its a fixed distance below the level its inserted on. Say insterted at level 3, the base is actually 2 meters below level 3. I dont want to place it and offset in the model, i would rather have it automatically set up so its in the correct place showing the level with a zero offset.
Any help is greatly appreciated, thanks!
Mon, Jun 16, 2014 at 6:53:24 AM | Parametric metal panel help
We don't ever model this.  A material works fine and will not overload your model.  Check out the stell select website for materials.
Perforated metal panel
Wed, Oct 30, 2013 at 7:36:33 AM
Question for metal cladding sheet as curtain panel attached to slopped roof
Sat, Jul 24, 2021 at 8:17:45 AM
Double Hollow Metal Door, parametric w/4 inches top - Revit Architectural 2008
Thu, Mar 27, 2008 at 9:31:00 AM
Wall Panel Location
Thu, Dec 14, 2006 at 11:49:47 AM
HELP - How do I apply metal roof panel to my existing Roof
Wed, Oct 8, 2014 at 10:37:02 AM
Page generation time: 0.1461
