Forums >> Revit Building >> Technical Support >> Problems with selecting mullion on curtain grid
Wed, Jun 11, 2014 at 10:13:11 AM | Problems with selecting mullion on curtain grid
neworleansaint
I have a storefront in my project. I want to replace the glazing panel with a storefront door. When I try to select the glazing panel it will not let me select the panel or any of the mullions.  I can, however, select the grid itself and the storefront as a whole.  I cannot window select and filter out the the mullions or panels themselves.  I then opened the project on another machine in the office and the storefront system works as it should and i have no problems selecting mullions.
Is this a setting I may have inadvertantly selected or deselected? I am currently working in Revit 2014.
Wed, Jun 11, 2014 at 10:38:30 AM | Problems with selecting mullion on curtain grid
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
In 2014-15 you can turn on a setting under the Modify tool so that you aren't able to select pinned elements, try that first.  Did you also try tabbing to the element you are trying to pick?
Wed, Jun 11, 2014 at 10:57:10 AM | Problems with selecting mullion on curtain grid
neworleansaint
The box for selecting pinned items was unchecked. This was the problem.   Thank you so much for the help, it saved me hours of headache searching.
Have a great day!!
Thu, Jun 12, 2014 at 2:57:54 AM | Problems with selecting mullion on curtain grid
AlphaDDC07
AlphaDDC07 Avatar
4 Stars: 6 Votes
Some times it's the simplest of things that frustrate you in Revit lol
Twelve highlanders and a bagpipe make a rebellion.
mullion with profile won't center on curtain grid
Thu, Jun 12, 2014 at 3:00:17 AM
Curtain Grid Problems [ 1 2 ]
Wed, Apr 10, 2013 at 5:57:45 AM
19
Curtain Mullion - Curtain Grid
Wed, Jul 24, 2013 at 8:19:24 AM
Mullion Join Glitch - Adding Curtain Grid Breaks
Thu, May 14, 2015 at 4:18:02 PM
mullion placement side/ curtain wall grid
Tue, Nov 17, 2009 at 11:24:45 AM
Page generation time: 1.6061
