18 Users Online (16 Members):
Forums >> Revit Building >> Technical Support >> Void extrusion not showing in section cut
Hello gang. I'm using Revit 2012. Showing a shower pan in 3d and section here. The extrusion cuts in any view but section. Anyone know why? All visibility settings are checked, but still won't show up in section. Thank You.
Look up cuttable in your HELP. Not all families can be cut.
Thank you for the reply. Void extrusions can be cut. I'm actually doing it at another spot in this plan. Something else is going on here.
Cut a void from an extrusion |
Thu, Feb 19, 2015 at 1:08:44 AM
Void Won't Cut Extrusion |
Wed, Feb 13, 2013 at 11:04:26 AM
Void Sweep won't cut extrusion |
Fri, Aug 24, 2012 at 3:02:42 PM
Void Extrusion in window family problem |
Mon, May 18, 2015 at 3:55:23 PM
void extrusion not cutting solid extrusion |
Fri, Oct 10, 2008 at 3:47:43 PM
