3 Users Online (2 Members):
Forums >> Revit Building >> Tips & Tricks >> i want my project north to be vertical.
Hi All, A guy who has no idea had modelled a huge project, now i am given a task to set it into correct coordinates,
i have no problem, with that process. what i discovered is project north and true north (both are in same angle) how do i get the project north to be vertical...
pls. help.
normally always all projects are drawn in true north, to be vertical (90 degrees) and when you import CAD rotate, align to grid and aquire coordinates it fixes it self...in this case i am not able to
cheers
W
Under Manage>Project Location tab>Position>Rotate Project North
Teafoe5, thank for the idea, what it was that i had to rotate true north first(to be looking verticle) , and then project north (by selecting a line / grid that is horizontal...) then i imported CAD grid intersection lines from survey dwg. and acquired coordinates. that fixed it all.
cheers
W
rotate PROJECT north (not true north) |
Wed, Jun 10, 2009 at 9:11:40 AM
True north help |
Tue, Jul 21, 2015 at 3:52:04 PM
True North vs Project North Linked dwgs |
Thu, Mar 10, 2016 at 10:02:26 AM
Spot Coordinate - True north vs project north |
Tue, Oct 22, 2013 at 4:42:05 PM
How to Rotate True North without rotating the whole Project? |
Thu, Mar 18, 2010 at 7:25:35 PM
