Forums >> Revit Building >> Technical Support >> External Glass Curtain Panel Problem
Fri, Jun 6, 2014 at 10:55:04 PM | External Glass Curtain Panel Problem
cbas1988
Hey there! I need to do a shopfront where the glass panels are outside the mullions. These pictures will explain better the problem. Basically I need to join the two glasses. I know that I can create 1 curtain wall for the glass and another curtain wall for the mullions and put them togheter but it doesn´t seem like the smart way to do it. If anyone of you guys can help me I would apreciate it a lot!
TThanks!!
I am using Revit 2012.
Tue, Aug 12, 2014 at 7:54:48 AM | External Glass Curtain Panel Problem
amw2210
You can use the storefront family type and then edit the family to input the mullions on the interior or exterior.
Tue, Aug 12, 2014 at 8:05:34 AM | External Glass Curtain Panel Problem
If you mean you don't like that gap then you have to create your own mullion profile.  When you do that, you will see this in the family:
Curtain Panels are trimmed to where the profile sketch intersects the Center (Front/Back) Ref Plane.
I don't see how you will overcome this but you can experiment with your profile.  Let us know what you learn.
Curtain system panel problem
Tue, Jul 10, 2007 at 10:08:07 AM
Panel tags for glass doors with frame in curtain walls
Thu, May 1, 2014 at 7:51:48 AM
curtain panel glass type
Sun, May 30, 2010 at 6:05:39 AM
Curtain wall - empty panel issue
Mon, Mar 25, 2013 at 2:34:28 PM
13
Graphic Override and Curtain Walls
Tue, Mar 3, 2009 at 7:26:02 AM
11
Page generation time: 1.2841
