Forums >> Community >> Newbies >> Hide Instance Parameter ruled by formulas from the Property Palette
Thu, Jun 5, 2014 at 4:46:39 AM | Hide Instance Parameter ruled by formulas from the Property Palette
SilviaEmme
Morning all,
I am creating families with a lot of parameters that needs to be ruled by formulas. I don't wan't them to be visible in grey, in the property palette as well as in the Edit Type box, once loaded into a project file. If I set them as type parameter they will appear in grey in the Edit Type box, on the other way round, as Instance, they will appear in the property palette.Ideas anyone?
Thank you for your help.
Thu, Jun 5, 2014 at 7:28:33 AM | Hide Instance Parameter ruled by formulas from the Property Palette
There is no way to hide this information.
Thu, Jun 5, 2014 at 7:51:56 AM | Hide Instance Parameter ruled by formulas from the Property Palette
SilviaEmme
Thank you for your kind reply.
Thu, Jun 5, 2014 at 8:58:19 AM | Hide Instance Parameter ruled by formulas from the Property Palette
nastyclown
nastyclown Avatar
4.5 Stars: 9 Votes
You might try using a shared parameter by instance, that way you could set a "hide" parameter in a filter,then filter by view with a view template.
Tue, Jul 1, 2014 at 4:18:13 AM | Hide Instance Parameter ruled by formulas from the Property Palette
SilviaEmme
With an incredible delay, but I would like to thank you all for your help.
Tue, Jul 1, 2014 at 7:03:26 AM | Hide Instance Parameter ruled by formulas from the Property Palette
nastyclown,
I'm always interested in new methods but you have lost me.  How can a view filter hide family parameters listed in the family type properties?  Can you tutor me?
Tue, Jul 1, 2014 at 9:45:59 AM | Hide Instance Parameter ruled by formulas from the Property Palette
nastyclown
nastyclown Avatar
4.5 Stars: 9 Votes
Actually is an instance parameter , but since you can create it with a shared parameter by instance, it can be listed in a schedule.
You can create a visibility yes/no parameter that drives the geometry, then a simple filter "parameter exist, yes/no"
to filter that info.
Tue, Jul 1, 2014 at 12:12:14 PM | Hide Instance Parameter ruled by formulas from the Property Palette
OK.... Filtering a schedule I can see but the question was how to hide them when you look at the family instance parameters and type parameters......   So the answer is still no - you can't do that.
Thu, Nov 21, 2019 at 11:26:43 AM | Hide Instance Parameter ruled by formulas from the Property Palette
mountain1985
if still struggling on this look at the below article. if you move some parameters about and make them shared, you can make them invisible in by changing items in the shared parameters file.https://aectechtalk.wordpress.com/2012/07/12/hiding-revit-family-parameters-in-a-project/
Variable Length Family with Array Formula
Tue, Aug 7, 2012 at 5:07:57 PM
Parameter formulas to select between two types then a instance
Sun, Jul 8, 2012 at 5:30:37 AM
Instance Parameter to control another Instance Parameter
Thu, Jul 22, 2010 at 6:22:48 AM
Parameter Formulas
Wed, Mar 21, 2007 at 12:48:43 PM
Hide parameter
Wed, Feb 4, 2015 at 3:29:43 PM
Page generation time: 0.6398
