Forums >> Revit Building >> Technical Support >> Simple Rectangular Toposurface Dividing Automatically... (Revit Arch 2014)
Wed, Jun 4, 2014 at 9:37:57 AM | Simple Rectangular Toposurface Dividing Automatically... (Revit Arch 2014)
cyoung603
I am trying to create a flat rectangular toposurface, very simple I know, but for some reason when I place the fourth point the surface splits into two parts.. Any ideas on how to correct this?
Wed, Jun 4, 2014 at 9:42:42 AM | Simple Rectangular Toposurface Dividing Automatically... (Revit Arch 2014)
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Are all of your points at the same elevation?
Wed, Jun 4, 2014 at 9:43:17 AM | Simple Rectangular Toposurface Dividing Automatically... (Revit Arch 2014)
You have not told us enough about your process or the problem.
Are you sure the surface splits or is that a topo line?
Wed, Jun 4, 2014 at 10:06:04 AM | Simple Rectangular Toposurface Dividing Automatically... (Revit Arch 2014)
cyoung603
All points are set at the default 0.0m. There shouldn't be any topo lines because it is a flat surface with all points set at 0.0m. Normally the fourth point would just extend the toposurface, but now it creates the square toposurface and created this random split
Wed, Jun 4, 2014 at 10:08:14 AM | Simple Rectangular Toposurface Dividing Automatically... (Revit Arch 2014)
cyoung603
On the left is a new revit file, I have done the same process as the created toposurface on the right
Wed, Jun 4, 2014 at 10:08:48 AM | Simple Rectangular Toposurface Dividing Automatically... (Revit Arch 2014)
Sorry but we don't think you did what you say.
Click on the edge of the topo, pick edit surface, then window it and post the image of the properties like I have.
Wed, Jun 4, 2014 at 10:12:12 AM | Simple Rectangular Toposurface Dividing Automatically... (Revit Arch 2014)
cyoung603
Wed, Jun 4, 2014 at 10:22:08 AM | Simple Rectangular Toposurface Dividing Automatically... (Revit Arch 2014)
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Does the line stay there when you finish the sketch?
Wed, Jun 4, 2014 at 10:23:09 AM | Simple Rectangular Toposurface Dividing Automatically... (Revit Arch 2014)
That is strange.   How do you only have one decimal place on your elevation properties?  I always have three decimal places on metric or feet settings.  Could it be that a point is at a different non-rounded elevation?
Wed, Jun 4, 2014 at 10:40:02 AM | Simple Rectangular Toposurface Dividing Automatically... (Revit Arch 2014)
cyoung603
The line does stay after the sketch is finished.
The reason there's only one decimal place is because the 'rounding' under project units is set to '1 decimal place'. I wasn't the one who originally created the file, maybe a point is at a different non-rounded elevation, how could I check for this?
Wed, Jun 4, 2014 at 11:00:54 AM | Simple Rectangular Toposurface Dividing Automatically... (Revit Arch 2014)
Window select all your points and in the propertise, replace that 0.0 with 0.00 and see what happens.
Wed, Jun 4, 2014 at 11:10:06 AM | Simple Rectangular Toposurface Dividing Automatically... (Revit Arch 2014)
cyoung603
Still nothing. The Revit tech at my company just came in so i'll see what he can do to help. Thanks Teafoe5 and WWHub.
Room Plans, Non Rectangular viewports from Revit 2014 and Python Shell
Thu, May 23, 2013 at 2:28:19 PM
Problem with a rectangular section on a adaptive arch
Sun, May 19, 2013 at 2:05:22 AM
Rectangular Flex Duct
Tue, Jan 21, 2014 at 2:45:16 PM
Toposurface in Elevations
Thu, Aug 27, 2009 at 1:51:06 AM
Problem with a rectangular section on an adaptive arch
Tue, Jul 16, 2013 at 8:50:32 AM
Page generation time: 7.4334
