Forums >> Community >> Newbies >> Cant select Objects
Fri, May 30, 2014 at 10:25:13 AM | Cant select Objects
gsmsmurck123
Help:  I cant select some duct and some units.  I have tried window select, i tried "select pinned elements", I tried selecting in 3D view.  Its like the duct and units are not there.  I need to modify these. Does anyone know what this could be?
Fri, May 30, 2014 at 10:37:38 AM | Cant select Objects
Did you create these elements?
Are they in your file or a linked file?
Are they in a design option?
Fri, May 30, 2014 at 2:16:44 PM | Cant select Objects
archigrafix
5 Stars: 4 Votes
What version of revit are you using?
Marc Faber
BIM Solutions Developer
goto.archi | Oslo, Norway
Fri, May 30, 2014 at 2:24:14 PM | Cant select Objects
gsmsmurck123
I figured it out.  I am a fabrication detailer and what I do is take eng. drawings and break the duct into fabricatable lengths and add fabricatable fitting.  I was trying to use the eng. drawing and he had 'design Options' in the drawing.  Thats why I couldnt select them.  I am editing the primary design option.  Thanks for the help.  This is the first time I have been on Revit city.  I am greatful for the quick response time.
Objects not staying selected
Sat, Dec 25, 2010 at 2:52:39 PM
12
Find objects in views using "Select All Instances in View"
Tue, Sep 3, 2024 at 5:10:21 AM
Selecting objects from a list?
Mon, Aug 15, 2005 at 2:29:26 PM
How to Scale Objects in Revit
Fri, Aug 25, 2017 at 1:13:47 PM
Select By Level
Mon, Dec 13, 2010 at 8:40:56 AM
Page generation time: 4.2127
