Forums >> Revit Building >> Technical Support >> Cut Roof with VOIDS
Mon, May 26, 2014 at 7:31:39 AM | Cut Roof with VOIDS
SteveB
3.5 Stars: 5 Votes
is there a way to cut voids out of roofs.  need to cut bits out of this existing conditions roof:  http://screencast.com/t/6B77plcTw
My solution is to create an in place roof model and apply voids.  Wondering if this can be done within the "roof" function.
Tue, May 27, 2014 at 8:01:33 AM | Cut Roof with VOIDS
We can't tell what you want to cut from your images.   You can sketch the edges of your roof and even openings while doing your roof sketch.  You can also use the opening tool and you can create in-place void families (roof category) and set those to cut your roof.
A Problem with Voids
Fri, May 18, 2012 at 8:41:19 AM
ROOF VOIDS
Tue, Dec 14, 2010 at 12:58:58 PM
Voids in Array cuts all elements, instead of only some
Tue, Jan 22, 2019 at 4:09:02 PM
Wall by face on curved solid - VOIDS not seen
Mon, Jul 29, 2013 at 1:29:54 PM
How do I make voids disappear in a family with a yes/no visible parameter?
Fri, Oct 27, 2006 at 1:05:08 PM
Page generation time: 1.2401
