Forums >> Revit Building >> Technical Support >> sketchy lines lineweight
Sat, May 24, 2014 at 1:28:35 PM | sketchy lines lineweight
SteveB
3.5 Stars: 5 Votes
is there a way to control the lineweight in graphic display options "sketchy lines".
  1. here is the way it comes out in "sketchy lines".. https://www.dropbox.com/s/rrubsvdtxa7hhqq/line%20grab.jpg   window jambs, doors, etc turn into too many lines close togehter and disaplay as fat line blob
  2. here is the prefereable thinner lineweight, which I could ony get with screencapture of the thinlines display of the same thing... https://www.dropbox.com/s/rrubsvdtxa7hhqq/line%20grab.jpg
Mon, Jun 9, 2014 at 1:21:59 PM | sketchy lines lineweight
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Not in from of my computer but I think it goes by 'object style' and 'visibilty graphics overrides' just like any other element. Override / change the lineweight of walls, doors, windows etc in the view to change the line weights of the sketchy lines. In other words the (wall, door, window) sketchy lines weight are controlled the same way the normal walls etc are. Try this CADclip
Mon, Jun 9, 2014 at 1:27:14 PM | sketchy lines lineweight
SteveB
3.5 Stars: 5 Votes
a work-around is to change the scale of the drawing.  Only helps if you are using the output as a .jpg and you don't care, can re-size the image.
Mon, Jun 9, 2014 at 2:10:11 PM | sketchy lines lineweight
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
There's no work around require. It behaves perfectly using normal processes.
Duplicate the view, do a visibility graphics override for lineweight (thinner) for the doors, walls, windows, roofs etc and Bob's your uncle.
Model Lines: Lineweight
Wed, Dec 10, 2008 at 11:23:42 AM
Model gone sketchy in 3d?
Wed, Oct 15, 2008 at 8:48:48 AM
symbolic lines
Thu, Jul 13, 2006 at 8:15:41 PM
Component - Model in place - Lineweight
Fri, Feb 10, 2012 at 6:43:03 AM
Sketchy Revit
Wed, Dec 7, 2011 at 11:17:39 AM
Page generation time: 1.4887
