15 Users Online (13 Members):
Forums >> Revit Systems >> Technical Support >> navisworks switchback
hi all. working with Revit and Navisworks 2014. had anyone had good luck using the switchback feature for exporting and revising the model? if so, please share your process. i have tried, but have issues with it. if i'm viewing the model in navisworks, i highlight a component and then press the switchback. when it opens up in Revit, it opens with the same camera angle, which usually puts me in the next room, or upstairs and i can't see the item. and Revit opens like 5 windows for some reason. i would like to figure out how to use it productively. i can see the benefit of looking at a problem spot in Navisworks, and going right to that spot in the Revit model to fix it, but i can't seem to make it work.
Try to learn at least one new thing every day |
I have never had full success with the switchback process. It's problematic and somewhat unpredictable. Especially with central files. It's a half baked tool. In other words it's not quite ready for production and needs to bake in the oven a little longer.
i'm glad to see that i'm not the only one that finds it hard to use.
. . . . not ready for production use. The clash detection itself however works awesome. Just stay away from switchback until further notice.
I am using Navisworks manage 2016 and Simulate 2016 and both switchbacks work well in a detached or Central File model. Hope this has changed for you both
Switchback stairs, stringer problem |
Wed, Jul 15, 2009 at 2:30:14 PM
Casper the Friendly Ghost Add-in NavisWorks 2016 |
Mon, Apr 25, 2016 at 5:01:17 PM
NavisWorks Exporter |
Mon, Mar 28, 2011 at 3:40:00 PM
Export Issue from revit to navisworks |
Thu, Apr 15, 2010 at 9:14:18 AM
2016 export Revit files to Navisworks without using Navisworks Exporter. |
Thu, Apr 21, 2016 at 4:53:15 PM
