Forums >> Revit Systems >> Technical Support >> Modifying a curtain panel system to add louvers
Wed, May 21, 2014 at 4:07:28 PM | Modifying a curtain panel system to add louvers
nebunic
I'm trying to modify this revit family: http://www.revitcity.com/downloads.php?action=view&object_id=11229 to add louvers instead of the glass it currently has, but I'm completely new to family editing and have no idea how to go about it.
I don't need the louvers themselves to be parametric, just for them to adjust in width and count to fit the height of my door, and i could even do without the height adjustment, as long as it works for a certain height. (All the panels I need to add will have the same height)
Doees anyone have any suggestions? I've looked for tutorials on how to do this but found none that are relevant to my issue Sad
Thu, May 22, 2014 at 7:45:56 AM | Modifying a curtain panel system to add louvers
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
"I don't need the louvers themselves to be parametric, just for them to adjust in width and count" This doesn't make sense, if you need it to adjust then you need it to be parametric.  If you look on youtube there are a lot of videos showing how to create parametric families.  You don't necessarily need one EXACTLY like what you are trying to do, you just need to understand the concept.  You should also read the Autodesk Families guide http://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles/Autodesk-Revit-Architecture-Families-Guide.html
Thu, May 22, 2014 at 1:39:16 PM | Modifying a curtain panel system to add louvers
nebunic
What I meant is I don't need to be able to adjust the blade length and/or thickness and/or spacing, and not even the number or width, if I can make them all a certain width that would work just as well.
Thu, May 22, 2014 at 2:53:35 PM | Modifying a curtain panel system to add louvers
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
So you just need to make extrusions then that is the length/width/quantity that you need.  If you don't know how to do that you need to read the families guide that I pointed you to.
Curtain system panel problem
Tue, Jul 10, 2007 at 10:08:07 AM
Glass louvers/ brise soleil
Mon, May 25, 2015 at 12:18:27 AM
Needing to create a flowing wall panel system.
Sat, Feb 13, 2010 at 2:28:18 PM
Curtain system > glazing panel matherial
Mon, May 28, 2012 at 1:02:14 PM
missing empty curtain wall system panel
Thu, Aug 4, 2016 at 7:17:33 AM
Page generation time: 2.0835
