16 Users Online (14 Members):
Forums >> Revit Building >> Technical Support >> Exporting to AutoCAD
4 Posts No Rating |
Hello everyone,
I would like to know is it possible to apply a CTB to a Revit export? I have sent a consultant files from 2013 Revit and the asked me to send them a CTB. So i created a using a PCP file from Revit 2013. Recently I have upgrade to 2014 and now 2014 Exports DWGs to different colors. I wanted to know is it possible to apply the CTB file from 2013 to 2014 to get Revit to export DWGs at the same colors that 2013 exported.
Thanks,
Jeff
How to create a ctb from a pcp.
http://vidarevit.blogspot.com/2008/08/converting-pcp-to-ctb.html
You can edit the export setup to give you whatever colors you want for each layer. Are you sure 2014 exports in different colors because I don't think so because it uses the standard AIA setup. Maybe someone has changed your export configuration or it was changed in your 2013 setup.
Trouble w/ exporting to AutoCad |
Thu, Jan 20, 2011 at 11:18:07 AM
Thu, Jun 20, 2013 at 1:24:08 PM
Exporting Layouts in to AutoCAD / piping issue... |
Thu, Sep 4, 2008 at 4:12:10 PM
exporting to autocad |
Fri, Aug 31, 2012 at 7:35:41 AM
Tue, Jan 30, 2007 at 11:32:22 AM
