Forums >> Revit Structure >> Technical Support >> How to Remove Furniture Tags
Tue, May 20, 2014 at 10:54:09 PM | How to Remove Furniture Tags
rosebomb
Hi All,
Im really stuck, I downloaded these furniture pieces however I can't seem to find in the edit type where to remove the text/tags in order to replace them with my own reference. If anyone has any ideas I'd be very appreciative, I've attached an image below to explain.
Wed, May 21, 2014 at 7:24:12 AM | How to Remove Furniture Tags
They are probably text in the family.  Click on the item, pick edit family, find and delete the text, then reload into project.
Thu, Nov 30, 2017 at 6:35:15 PM | How to Remove Furniture Tags
calber2011
Has anyone figured this out?  I'm really stuck on this.  I've downloaded some office furniture and there is large text on it that I cannot see in the original family file.  I can't seem to find a way to get rid of it.
Fri, Dec 1, 2017 at 1:20:54 PM | How to Remove Furniture Tags
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
As WWhub said. Open the family in the family editor. Go to the view where you see the text i.e. probably the plan and zoom in until you see some text and delete it and purge the family and load it back into your project model.
Fri, Dec 1, 2017 at 1:32:37 PM | How to Remove Furniture Tags
calber2011
Beaucoupnice, as I stated I tried that, however, I cannot see text when I open it to edit it...
Fri, Dec 1, 2017 at 3:16:59 PM | How to Remove Furniture Tags
I need to ask the obvious question.  When you edit the family, do you check VG to see if the category is on?
Another possibility is since the text is 3D, could it be at a level above the plan you are looking at?  Look at a 3D image in the editor witl all categories on in VG.
Sat, Dec 2, 2017 at 8:33:07 AM | How to Remove Furniture Tags
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
Attach the family
Mon, Dec 18, 2017 at 9:54:11 AM | How to Remove Furniture Tags
aaronjburkhart
Knoll furniture adds their annotated tags as families within the model you download. Go to your project brower of the d'urso model> families > annotation symbols> right click and delete the tag (it'll warn you you're deleting the family... no problemo it's just the tag family)... and boom goes the dynamite. Before/After what your annoation symbols should look like after.
Mon, Dec 18, 2017 at 10:17:31 AM | How to Remove Furniture Tags
calber2011
aaronjburkhart, THANK YOU!
Furniture Tags & Sketchup Furniture Components
Fri, Dec 4, 2015 at 9:35:33 PM
Family/furniture tags
Thu, Feb 6, 2014 at 7:29:24 AM
Creating Furniture Tags Custom
Tue, Feb 11, 2014 at 5:29:58 AM
Embedded furniture tagging
Thu, Jul 22, 2010 at 12:37:04 PM
Difference between Furniture & Furniture Systems
Thu, Jan 4, 2007 at 2:37:47 PM
Page generation time: 8.3880
