Forums >> Revit Building >> Technical Support >> Staggered tile PAT file needed: 96" W x 21" H
Tue, May 20, 2014 at 2:44:23 PM | Staggered tile PAT file needed: 96" W x 21" H
avilarchitect
Hello! hope everyone is enjoying revit!
how is a staggered tile pattern created? i am in need of a staggered tile pattern that is 96" Wide x 21" High. Any help
would be greatly appreciated. i ma running revit architecture 2015, updated release 2
thank you
Tue, May 20, 2014 at 2:53:17 PM | Staggered tile PAT file needed: 96" W x 21" H
When you say staggered, do you mean like a block pattern?  If so, then now is a good time to learn.  Find a copy of the concrete 8x16 block pattern and edit it to your 21 x 96 pattern.   Really very easy and once you do it, you can make as many staggered patterns as you need.  Just edit the .pat using a simple text editor and rename it when saving, then load that pattern file.
Tue, May 20, 2014 at 2:57:45 PM | Staggered tile PAT file needed: 96" W x 21" H
Here is a simple running bond pattern - create a new one using notepad;
*10.5x15 Stretch running bond;%TYPE=MODEL0,       0,0,      0,10.590,      0,0,      10.5,7.5,           10.5,-10.5
Change the 10.5 to 21 and the 7.5 to 48 (1/2 of the length)
This is a model pattern.
Save with a .pat extension.
Tue, May 20, 2014 at 3:12:39 PM | Staggered tile PAT file needed: 96" W x 21" H
avilarchitect
thank you soooo much!
Tue, May 20, 2014 at 3:19:02 PM | Staggered tile PAT file needed: 96" W x 21" H
oops ... when I pasted this in, the returns did not show.
;%TYPE=MODEL
0,       0,0,      0,10.5
PAT file: 12 x 24 staggered tile
Tue, Mar 21, 2017 at 11:45:09 AM
Custom model tile pattern
Fri, Jul 1, 2016 at 5:29:27 PM
Import PAT File
Tue, Dec 14, 2010 at 9:42:43 AM
help with .pat custom file.
Mon, Oct 13, 2008 at 8:25:57 AM
How do i make an allternating horizontal 4" and 8" .pat file in notepad???
Tue, Sep 6, 2011 at 6:32:54 PM
Page generation time: 2.4739
