Forums >> Revit Systems >> Technical Support >> How do I edit a single panel on a door in Revit 2014?
Tue, May 20, 2014 at 8:44:38 AM | How do I edit a single panel on a door in Revit 2014?
NiiPuu
Hello, currently I'm having an issue... I'm unable to figure out how to edit a single panel by changing it into glass on a specific door (I've added a screenshot of it below), I've only been able to figure out how to do it on all panels at once.
Any tutorials would be greatly appriciated.
Thanks!
Tue, May 20, 2014 at 9:17:54 AM | How do I edit a single panel on a door in Revit 2014?
You will have to edit that door family and assign an instance parameter to the door panel material.  Then it can be edited by instance..... of course you could also make it be a type parameter - up to you.
Tue, May 20, 2014 at 9:31:58 AM | How do I edit a single panel on a door in Revit 2014?
NiiPuu
I'm sorry, but I am confused on what you mean. Would it be possible to more clearly explain on what your suggestion is?
Tue, May 20, 2014 at 9:57:00 AM | How do I edit a single panel on a door in Revit 2014?
If you need to learn how to edit a family, then find some tutorials.  Also download the "families guide" from the autodesk website.
Nested 3d door panel parametric swing and the width problem
Tue, May 21, 2013 at 7:58:01 AM
11
REVIT 2014: Door Elevations - swing lines are shown backwards? [ 1 2 ]
Tue, May 12, 2020 at 2:41:52 PM
16
curtain wall panel widths
Sat, Feb 1, 2014 at 10:12:15 AM
Adding a Single-segment mullion to a curved curtainwall
Sat, Feb 9, 2008 at 8:00:15 AM
Sliding Door with Louver
Thu, Jan 23, 2014 at 10:58:08 PM
Page generation time: 8.0978
