Forums >> Revit Structure >> Technical Support >> PRECAST STAIR STRINGER
Mon, May 19, 2014 at 10:08:56 AM | PRECAST STAIR STRINGER
akunkinga
How do I change the stringer width on my precast stair to 175mm and extend the landing
thanks
Mon, May 19, 2014 at 12:28:50 PM | PRECAST STAIR STRINGER
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Edit the stair landing and edit the boundray line to extend where you want it.  You can tab to select the stringer and edit the type to change it to the type that you want, you may need to create a new stringer profile.
Mon, May 19, 2014 at 8:44:39 PM | PRECAST STAIR STRINGER
mansell5
3.5 Stars: 4 Votes
u need to edit the type properties of your stair.
scroll down to stringers and look for the stringer carriage ht (set at 150 default, change to 175mm) and you are done.
Monolithic Stair with Stringer
Wed, Aug 5, 2009 at 10:43:24 AM
Stair Stringer Question
Fri, Jul 28, 2017 at 4:01:08 PM
Stair Stringer Offset
Wed, Jul 15, 2009 at 2:20:56 PM
Precast stair with notch connection
Fri, Aug 26, 2016 at 1:05:15 AM
Stair stringer offset (2015)
Mon, Sep 14, 2015 at 9:19:19 AM
Page generation time: 0.9287
