Forums >> General Discussion >> Revit Project Management >> the construction of new panel???
Mon, May 19, 2014 at 12:32:51 AM | the construction of new panel???
arch87
Hi Guys good to be back... i have a project that is all about panels, all my walls are simple sheaped at ground level. therfore i used the generic wall to make all my panel walls. and i used the split with gap tool to create the panel joints. so far is good.
but i need to know if the above method will not be complicated later on or i should from now consider changing my panels to be curtain walls?
also i need a short cut... when i finish drawing my panels how can i eassily prepare it for shop drawings, you know without doing too much detail drawings and etc, iam sure revit have a way around panels for shop drawings??, iam new to panel and shop drawings thats why????   any tips and tricks or advice will be ladly appreciated
thank you in advance
Building Arabic style panel
Tue, May 26, 2015 at 9:48:09 AM
how to create video in stages of construction
Sat, Mar 21, 2015 at 12:27:46 PM
customerized curtain panel doesn't work with the irreglar shaped panel?
Sat, Jul 10, 2010 at 1:48:42 PM
Newb Question: Tilt Up Panel
Fri, Apr 16, 2010 at 1:00:49 PM
12
Tilt Panel Curtain Wall - On the right track?
Sat, Nov 10, 2012 at 7:17:55 PM
Page generation time: 1.5329
