19 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> First Project
Hey guys, excited to start. It would be great if some people could answer painful little questions for the beginner.
I dont want this grade line to show in my perspective, But i cant hide the element in view because I need the grade to cut the wall on the angle of the real grade. I also would like to show the line of the wall making contact with the grade
Any suggestions?
Autodesk's Revit 2014 User
-Sean |
Add a building pad to your topo using the exterior wall line. That will give you what you want.
I couldnt find a building platform to add, I can only edit the topo and inside the editor to place points
Edited on: Tue, May 20, 2014 at 7:33:16 AM
-Sean |
Read this topic in your HELP:
http://help.autodesk.com/view/RVT/2015/ENU/?guid=GUID-A964AA13-39B6-4A4C-A230-9F69C8AA5D3A
hey thanks that helps alot, Is there anyway to remove the topo grade lines though? I dont need to see every 2' of grade lines. Maybe there is a tolerance I can set or something?
-Sean |
Again - this is in your HELP searching contour:
http://help.autodesk.com/view/RVT/2015/ENU/?guid=GUID-3BC58B4D-5415-4434-86F6-E02D81840A4C
thanks i will look at this - I dont know where to begin to look in the help when i try and use it. Thanks for pointing me in the right direction.
-Sean |
To use your help,
- Use simple, one word searches
- Try similar words when you can't find what you need. (In this case topography didn't get what you needed so then I used contour)
- Make sure you look at all of the sub-topics in a search category.
The more you search and read or at least scan the topics in your searches, the quicker you will learn. Even failed searches will teach you something.
Mirror Project - Revit Architecture 2013 |
Sat, Jan 25, 2014 at 5:41:31 AM
project standards |
Wed, Feb 1, 2012 at 11:18:52 AM
Cannot Edit Label After Inserting into Project |
Fri, Sep 14, 2012 at 7:07:14 PM
Having more than one project north within a project? |
Fri, Mar 26, 2010 at 7:05:09 AM
Revit Architecture 2013 - Track time for project or history of project |
Mon, Nov 4, 2013 at 2:09:27 PM
