22 Users Online (20 Members):
Forums >> Revit Systems >> Technical Support >> Downloaded Manufacturer Light Family - can't circuit
Good afternoon all,
I downloaded a light family from Philips - http://www.colorkinetics.com/ls/rgb/colorblast12pc/, and I'm having trouble getting the light fixture to circuit up. My electrical distribution system is set correctly as I'm not having problems with any other light fixtures being circuited. I checked the family of the light fixture and it appeared to be partially okay with the electrical connector - I did add the voltage parameter into the Electrical group parameter. Even after defining that as 120V, I still don't see any 'panels' listed when I got to select the panel when trying to circuit up these lights. Any insight, tips or tricks would be greatly appreciated. If you want to see the family yourself, see this link: http://www.colorkinetics.com/support/Revit/ColorBlast_Powercore.zip
Thank you!
Brian
Disregard, I figured it out.
Change Identity Data on Manufacturer Family |
Thu, Mar 14, 2013 at 2:33:14 PM
Question for downloaded Pella DH Family |
Fri, Mar 31, 2006 at 11:49:17 PM
downloaded the window AC but can't insert it |
Mon, Oct 2, 2006 at 9:29:34 AM
Circuit Homerun |
Tue, May 5, 2009 at 1:40:57 PM
Panel Schedule Circuit # Parameter |
Wed, May 31, 2017 at 11:56:25 AM
