Forums >> Revit Building >> Technical Support >> Railings and Stairs
Fri, May 16, 2014 at 12:08:33 PM | Railings and Stairs
SBme
I am trying to build a two-run stair. The default stair has a railing going all around the landing. Regardless of the application, there is no need to extend the handrail around the landing - guardrail yes, but not handrail. I have been trying to figure out a way to accomplish this, and that's where I'm running into problems.
- If I try to split the railing, it doesn't work as it's still all only 1 railing type.
- If I try o trim the railing, I can't get the new railing to host to the stair (I can't select the stair to tell it to host).
- If I try to sketch a freestanding railing outside of the stair, I can't host it to the stair, so it becomes a dumb object (very un-Revit like). And that's not talking about having to figure out to do the sloped railing on the second leg of the stair.
So, did I miss the proper option? So far all the searches that I've done resulted in nothing usefull. It's as if this is not a problem. Am I the only one?
Thanks for your help
System: Revit 2014 (update release 2) on Quad-Core Thinkpad w/ 64-bit Win7 & 8Gb Ram.
Fri, May 16, 2014 at 12:12:16 PM | Railings and Stairs
  1. Edit the railing family
  2. Copy the entire sketch to clipboard
  3. Now delete all of the sketch except your first run
  4. Finish that railing
  5. Copy that railing in the same place
  6. Now edit this railing
  7. Delete the sketched line, paste in your copy/clipped sketch
  8. Delete all of the sketch except your second run.
  9. Finish.
Fri, May 16, 2014 at 12:44:48 PM | Railings and Stairs
SBme
That worked, thanks. Rather convoluted way of solving something that should be very simple. Then again, at least we have sketchy lines in 2015... :/
My railings doesn't go with my stairs
Mon, Dec 2, 2013 at 11:45:03 AM
14
Problems attaching railings to stairs
Mon, Dec 2, 2013 at 10:49:14 AM
Attaching railings to stairs?
Wed, May 24, 2006 at 1:48:05 AM
Railings
Mon, Oct 31, 2005 at 6:23:30 PM
Detailing/dimensioning stairs and railings
Fri, Mar 16, 2007 at 2:14:13 PM
Page generation time: 0.0761
