Forums >> Revit Building >> Technical Support >> multi-category tag
Fri, May 16, 2014 at 10:20:42 AM | multi-category tag
palowe
I started tagging the kitchen equipment and used multicategory tag. So when I started tagging furniture items i create a tag named furniture so it doesn't interact with kitchen type marks. But it doesn't work. When i type number 1 to an item it overwrites the number 1 item that i had in the kitchen.
Thanks,
Fri, May 16, 2014 at 10:37:55 AM | multi-category tag
We don't know enough about your tag, what parameter it is reading and what parameters are in your elements.
Are the elements seperate or are they nested in one family?
Fri, May 16, 2014 at 10:42:07 AM | multi-category tag
palowe
I see they are both family type generic model, so i thought of create a family type named kitchen and another one named furniture, so the tags will reconize they are different elements. but i don't know how to change this family type... is this making sense?
thanks
Fri, May 16, 2014 at 11:08:29 AM | multi-category tag
cdhackett
>Edit the family
>Under properties>Go to family category and parameters
>Go through the list until you find the type of element you'd like and click on it
>Hit ok
>Load family into project
That should do it for you.
Fri, May 16, 2014 at 11:53:42 AM | multi-category tag
palowe,
You need to spend some time with tutorials and written data on families and parameters.  I suggest you download the "families guide" from the autodesk site to start because it will give you fundamental knowledge.
Multi-category tags are just that.   They tag the same shared parameter that is added to families of different categories.  You said that your tag changed the value of other families.  That can't really happen unless all of your families are really just different types of the same family.
Problem with Multi Category tag
Mon, Apr 3, 2006 at 12:48:41 AM
Multi category tag in Revit 8.
Mon, Mar 27, 2006 at 10:33:20 PM
Multi-Category Tag with horizontal leader lines - RAC 2012
Wed, Feb 15, 2012 at 4:29:14 PM
Space "number" parameter to Multi-Category Tag?
Fri, Dec 13, 2013 at 10:26:02 AM
Leader Line Line weights
Sat, Feb 7, 2009 at 7:26:00 AM
Page generation time: 1.0895
