Forums >> Revit Building >> Technical Support >> Doors in plan
Tue, May 13, 2014 at 8:32:42 AM | Doors in plan
mushroomheadache
Hi All,
Just getting to grips with Revit (LT 2015) and I would like for fire doors in plan to shaded solid black so that they are easily distinguished.
I've tried but with no avail...
Thanks in advanced
Scott
Tue, May 13, 2014 at 12:20:32 PM | Doors in plan
You would have to assign a material to those doors>  That would prbably require you to edit the family and change the door material.
Tue, May 13, 2014 at 1:24:08 PM | Doors in plan
Johnzo142
Even so, typically the plan representation for doors is not the actual geometry but symbolic lines.
Tue, May 13, 2014 at 1:38:16 PM | Doors in plan
Johnzo,   You are correct.   I should have said that. - good catch
In this case, the family could be edited to show a solid filled region turned on/off with a parameter switch.  The door leaf is usually modeled closed and my first answer was incorrect.
Tue, May 13, 2014 at 1:42:41 PM | Doors in plan
Johnzo142
Unfortunately, you can't place a filled region in a door family either. Unless you know something different.
Tue, May 13, 2014 at 1:44:50 PM | Doors in plan
You can place a filled region using a detail component.
Doors on plan vs elevation
Thu, Jan 14, 2016 at 7:48:16 AM
Doors are missing in plan
Fri, Jul 22, 2011 at 8:42:47 AM
Windows and doors not showing up in walls
Mon, Nov 8, 2010 at 3:24:05 PM
Area plan not printing walls and doors below colors
Sat, Mar 14, 2015 at 1:26:36 PM
Phase "new" in plan: doors cut pattern same as wall
Tue, Dec 8, 2015 at 7:40:25 AM
Page generation time: 2.9105
