Forums >> Revit Structure >> Technical Support >> Structural Foundations Corner Join Problem
Tue, May 13, 2014 at 7:42:31 AM | Structural Foundations Corner Join Problem
TeamNga
1 Stars: 1 Votes
Hi all.
Our engineer is asking us to correct a line problem on our foundation plans. (Image 1)
The problem is caused by one footing going streight and the other butting into its side. (Image 2)
Can we miter structural foundations like walls? If not does anyone have a solution for me?
Thanks.
Tue, May 13, 2014 at 12:17:29 PM | Structural Foundations Corner Join Problem
He's crazy to complain about this.....
Tue, May 13, 2014 at 12:45:34 PM | Structural Foundations Corner Join Problem
TeamNga
1 Stars: 1 Votes
And that's just the tip of the iceberg of his demands. He is suggesting going back to autocad.
N-A-WAY.
Any ideas?
Tue, May 13, 2014 at 1:00:50 PM | Structural Foundations Corner Join Problem
If he can't see the trees then maybe you need a different engineer.
Even if you add a tiny masking region to break that line, the dashed lines would then bother him because they would not be even. .... BALONY  When we hand drafted, our linetypes were not perfect and it didn't matter.  Not then and not now.
Roof Join at a Corner
Mon, Aug 27, 2007 at 10:33:22 AM
Joining isolated foundations to concrete beams - 2009
Thu, May 7, 2009 at 1:43:52 AM
corner join
Tue, Mar 14, 2006 at 3:52:38 AM
Isolated Foundations at corner
Wed, Jul 23, 2014 at 12:42:58 PM
beam join command
Sun, Dec 23, 2012 at 11:50:10 PM
Page generation time: 2.1125
