Forums >> Revit Building >> Technical Support >> Problems linking DWG CAD files into Revit
Tue, May 13, 2014 at 5:11:23 AM | Problems linking DWG CAD files into Revit
Carro
Hi all,
this might be a beginners problem however hopefully this will then be easy for some of you to help me with!
I am setting up a new Revit project and am linking in DWG files that I have set to UCS World coordinates in Autocad.
In Autocad they stack up in the same location but when linked into Revit at Origin to Origin setting they are slightly off from each other.
Does anyone have any clues to why this happens??
Thank you!
Wed, May 14, 2014 at 10:33:52 AM | Problems linking DWG CAD files into Revit
While I don't know why they don't align the same, I will say that origin in Revit is very different than CAD. There was a very good article in an AUGI publication a couple of years ago that helps explain how Revit's origin works.
Shared coordinates is the best way to control linking.
DWG linking into revit
Mon, Jun 9, 2014 at 7:11:38 AM
Linked CAD files are not turning off
Tue, Nov 29, 2016 at 3:31:28 PM
14
Link CAD - problems
Wed, Mar 19, 2014 at 7:42:47 AM
Help: Aquiring CAD Coordinates/Linking/Multiple building drawing set/ Problems
Wed, Dec 19, 2007 at 5:06:04 PM
linking dwg files in elevations
Wed, Nov 23, 2005 at 3:04:32 PM
Page generation time: 1.5382
