15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> Trim and frame does not adjuts to wall as expected
26 Posts No Rating |
I have created my 6 panel door. My frame adjust to the varing door widths but will not adjust to a new wall thickness. Also, I can't seem to get my trim to adjust to varing door sizes. I haven't placed it in a project with the trim on it yet but I presume that the trim won't adjust to different wall thicknesses either. Any help would be appreciated.
J
Again you'll probably have to post the file.
go to your family and make sure that the frame is locked to the wall reference lines, same with your trim...
Ok here is the file. I would like to make the jamb and trim adjust to a varing wall thickness and the trim also needs to adjust to varing door widths. If you can let me know how to do it that would be great. I don't nescessarily want anyone to fix it for me, I won't know how to do it if that happens.
Thanks for all the help!
J
I had to add reference planes to the Exterior and Interior Finish. I then removed your trim sweeps and redrew them with the Exterior and Interior Finish as the working planes.
To get the Jamb and Door panel to stretch with the wall I had to lock dimensions from the Interior Finish working plane to each element of the jamb and door panel.
Hope that helps.
Post edited on 2006-03-01 12:26:09
flip control only door panel & not frame/trim revit 2015 |
Mon, Apr 27, 2015 at 10:19:19 AM
Control Position of Door Frame/Panel in Wall Thicker Than Door Frame |
Thu, May 6, 2010 at 7:29:41 AM
wall trim under an eave |
Wed, Feb 8, 2006 at 12:15:12 PM
Vertical trim ***PLEASE HELP**** |
Tue, Jun 12, 2012 at 8:05:22 PM
Stone wall covers door and window trim? |
Thu, Jan 3, 2008 at 8:50:32 AM
