13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> Rooms within a GIA Area Plan
Revit 2013:
We have a block of apartments, to which we have created a GIA Area Plan, which schedules out the area for each apartment.
Obvioulsy each apartment contains a number of rooms (kitchen/ bedroom/ bathrooms/ etc). Is it possible to schedule out which rooms are located within each of the GIA Area zone?
I could use Departments, hwoever, I have several parameters (Tenure/ Phasing/ Postal Addresses) attached to the GIA Areas, which I would like to utilise and don't wish to double entry.
Any help/ pointers would be appreciated!
Craig |
2 Posts No Rating |
Could you add a parameter for the GIA Area zone and then group your schedule by that parameter?
Using Revit2014, dragging the rest of the company with me from AutoCAD2008. When will the whining stop? |
How do I go about doing this?
Currently, if I create a 'Room Schedule', there is no option to select the Area GIA Parameters in the Select available fields dropdown. Likewise the same is true if I create an 'Area (GIA) Schedule, the Room parameters are not available in the dropdown.
Craig |
Craig |
2 Posts No Rating |
Yeah, you can't schedule rooms and areas together. Have you tried doing both with areas? You could make two different area plans and then overlay one on the other. Then you could name the previous rooms something like A1-Kitchen (Apartment 1, Kitchen).
Housing. Plot Label linked to Area Schedule -to show the total GIA of all floors |
Wed, Jul 13, 2011 at 9:42:36 AM
New Area Plan in phased model |
Tue, Dec 8, 2009 at 12:39:13 PM
Schedule Rooms Within areas of a specific area plan |
Mon, Nov 25, 2013 at 12:59:18 PM
Total area of rooms in a department vs. programmed area for that department |
Wed, Jul 3, 2013 at 11:12:20 AM
Use Area Plan as my Floor Plan? |
Fri, Aug 30, 2019 at 12:31:02 PM
