Forums >> Revit Structure >> Technical Support >> Roof textures messed up in renderings
Fri, May 9, 2014 at 8:50:03 AM | Roof textures messed up in renderings
TytusHamilton
When doing a render in cloud of my house in revit the texture on my roof is all blown up and look rediculous, but when im looking at them in revit they look fine and are normal size. It is only the textures on my roof that does this. Any idea why?
Wed, May 14, 2014 at 7:06:23 AM | Roof textures messed up in renderings
HKicsak
When you look at it in Revit, are you looking at it in Realistic? And is it an Autodesk material? If you're using your own material it may not translate to the cloud rendering.
Fri, May 16, 2014 at 9:10:22 AM | Roof textures messed up in renderings
TytusHamilton
When looking at it in realistic it looks fine, like it should. I have had this issue with both autodesk materials and custom materials found on a different website.
Fri, May 16, 2014 at 9:17:14 AM | Roof textures messed up in renderings
What Revit and what updates do you have installed?
Having issues with roofs blending together on renderings
Mon, Aug 15, 2016 at 3:06:41 PM
11
free hi res textures
Mon, Apr 13, 2009 at 2:47:29 AM
Sun too "white" in interior renderings
Thu, May 10, 2012 at 12:52:11 PM
Revit render textures - any good resources on the web?
Thu, Dec 16, 2010 at 10:54:15 AM
adding textures to wall
Tue, Oct 17, 2006 at 9:27:46 PM
Page generation time: 2.0101
