Forums >> Community >> Newbies >> DIMENTION STYLE,
Thu, May 8, 2014 at 9:22:17 PM | DIMENTION STYLE,
yojano
  HOW CAN I HAVE THE DIME STYLE WITH A GAP BETWEEN THE TEXT, COUSE I TRYING TO LINE IT BUT LINE GOES THROUGH THE MIDDLE OF THE NUMBER, IS IT POSIBLE TO SET IT LIKE IN AUTOCAD.
  HERE IS THE LINK WITH THE IMAGE OF THE PROBLEM:http://screencast.com/t/I1Cw8TVf
 THANKS.
Fri, May 9, 2014 at 8:27:34 AM | DIMENTION STYLE,
Johnzo142
There is no way to do this automatically since you can't set your text offset to a negative value. You would have to make sure your text background is set to opaque and manually drag your text into position for each segment. Not worth the trouble.
Fri, May 9, 2014 at 12:33:04 PM | DIMENTION STYLE,
yojano
ok, thanks, i have check obout it but it doesnt look the way i want it.
   thanks anyway.
Dimention rounding in different views
Fri, Jan 9, 2009 at 6:00:01 AM
RAC 2009 dimention text location
Wed, May 13, 2009 at 7:00:41 PM
Dimention to a curve in elevation
Tue, Aug 11, 2009 at 8:04:12 AM
How to add and edit an annotated dimension and room tag
Sat, Apr 10, 2010 at 5:29:55 AM
Trusses
Wed, Oct 24, 2012 at 6:06:23 PM
Page generation time: 0.2036
