Forums >> Revit Systems >> Technical Support >> Revit MEP not allowing me to make changes, and it is deleting objects when I try
Thu, May 8, 2014 at 8:07:20 AM | Revit MEP not allowing me to make changes, and it is deleting objects when I try
NettoSaito
The other day I received a new Revit model for a project I've been working on, and it is having some issues with it. For some reason, I cannot make any changes to it outside of minor moves, and placing dimensions/elevations. Whenever I go to add a new pipe, it vanishes (already checked my view settings/view range), when I try to disconnect or split a pipe and reconnect it (just as a test), the pipe deletes itself and states it cannot auto rotate (despite the pipe being straight on the same elevation), and whenever I do move a pipe, the fittings will delete themselves as well.
I have already checked the families, everything is there, and I was even able to get new CVS files. Everything appears to be completely fine on my end, but for whatever reason these issues are still happening. I have tried opening the model with Revit MEP 2012 (which is the version it was created with), I have tried opening it with 2014 (which is what I would be using to work on it), and I have tired opening it in 2015. The same issues happen in each version of Revit MEP.
Does anyone have any idea what could be the problem? Sorry I can't provide you with any more information or error messages, but there really are none. The families are loaded into the project (I also redownloaded the families and reloaded them just to be sure), the CSV files are there, it is a local file, and every setting I've checked is as it should be. I am at a complete loss on what could be causing this.
deleting levels without deleting associated objects on it.
Thu, Aug 1, 2013 at 6:20:35 AM
REMOVING CAD IMPORTS IN REVIT MEP 2011 AFTER DELETING
Thu, Sep 9, 2010 at 10:23:27 AM
Can individual Objects be bound in Arch then changed in MEP
Thu, Jun 7, 2012 at 1:37:23 PM
Revit MEP or AutoCad MEP
Fri, Oct 14, 2011 at 8:21:49 AM
Exporting from Revit 2013 to Autocad MEP 2010 while retaining intelligent object
Sat, Dec 7, 2013 at 12:08:38 AM
Page generation time: 6.0056
